Replacing door seal for Whirlpool AWG 280/ 7
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Replacing door seal for Whirlpool AWG 280/ 7
  • #21366
    ben 365
    Could you give me some guidance with how to replace the door seal for the Whirlpool awg 280 / 7. It seems easy enough to just pull the old one out and jimmy the new one in, however I don’t want to end up with another flooded flat. Your help would me greatly appreciated.
    #190612
    Re: Replacing door seal for Whirlpool AWG 280/ 7
    ben 365 wrote:It seems easy enough to just pull the old one out and jimmy the new one in
    First you will need a replacement seal from here 🙂
    Then you disconnect the machine from the electricity…… :zap:
    Then, armed with the right tools, remove the front panel and you will be able to “jimmy” the rest I’m sure?
    …..if not? then click on the link below for a local engineer to fix it for you. Who knows he may be called Jimmy? 🙂
    #190613
    ben 365
    Cheers matey, will give it a go
