Hello all. I would appreciate any advice about a fridge freezer that can replace the one that is currently fitted in to an existing kitchen. It is an old Ariston fridge freezer with a model number of OK AF 3100 and there is a serial number. the dimensions are ( as best as I can get at with the carcass) height 1750mm, width 540mm and depth 460mm. It is a 70:30 split. I have nobody to help me with this and haven’t a clue how to get something that will replace the old one and that will be able to fit inside the existing housing; all the models I have looked at seem different sizes. I thought these would be standard! tThank you for any advice.
You have a 70:30 integrated fridge freezer which is of a standard height 😀 I would simply take a couple of pictures and visit my local independent retailer or kitchen supplier who should be able to supply and install a replacement for you.
