replacing neff oven element, troublesome screws any advice
Home Forums Public Support Forums Help And Support Cooker And Oven Forum replacing neff oven element, troublesome screws any advice
  • #12745
    beginer
    This is probably an easy question for someone. My Neff double oven is great but the main oven stopped heating up. Fan works so i think it is the element that has gone. tried to replace but i cant get the screws that hold the front plate inside the oven to unscrew any ideas. worried about using wd40 as it may be flamable. I would be greatful for any advice. I have taken the oven out of its case to disconect wiring to element. Hope to hear soon. thanks in advance. [/img]
    #151459
    Brains
    Re: replacing neff oven element, troublesome screws any advi
    Whats the model no, ENF etc? You will find this info around the door area
    #151460
    beginer
    Sorry you can see why i called my self beginer it is a Neff u 1721 hope that makes sence to you.
    #151461
    beginer
    sorry it is a Neff u1721
    #151462
    Dave_Conway
    These are always tight and the heat doesn’t help πŸ˜‰
    Perseverance I’m afraid to be honest.
    #151463
    Bryan
    beginer wrote:i cant get the screws that hold the front plate inside the oven to unscrew any ideas. worried about using wd40 as it may be flamable. I would be greatful for any advice. I
    No problem with a small squirt of wd40 to help loosen screws , just wash it off when/if you get the back plate off. You may still get slight smell when you get heat back in the oven (new element) but it`ll pass in a few minutes.
    Power off at all times of course :zap:
    Bryan
    #151464
    deltra
    bit of wd40, then a pair of mole grips as tight on to screw head as poss.(sometimes have to file one edge flat to get good hold)
    #151465
    BSH-MAN
    Unplug then remove oven from housing, remove back panel to access the sharp end of the screws, add a little WD40 and the use mole grips on screw threads.
    Don’t leave cooked food in the oven, as this contains moisture
    πŸ˜‰
