I need to replace faulty simmerswitch on my Tricity Ceramic hob.
Existing switch Diamond 33ER3HT is replaced by No. 43ER105B1. My problem is the new item has 8 poles ( after jumper is installed as per diagram) while there is only 7 spade ended wires to fit; also existing switch poles are named but the new one is numbered. If anyone out there can supply a diagram of how to wire this switch you’ll gain a friend for life.
Thanks for any time you may spend on this
Wilmur
