Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Replacing the Boot Gasket on a Bosch Exxel 1400
- This topic has 8 replies, 6 voices, and was last updated 19 years, 7 months ago by
Wizz.
September 6, 2006 at 11:44 am #20617
Wizz
ParticipantCan anyone tell me how to go about replacing the Boot Gasket on a Bosch Exxel 1400 washing machine? It looks as if I need to remove the door and main front panel to get at the seal between the gasket and the outer drum but where do you start?!
September 6, 2006 at 1:41 pm #187729Martin
ParticipantRe: Replacing the Boot Gasket on a Bosch Exxel 1400
You need to do exactly that and if you give us the full model number, we can supply you with a replacement gasket as well! π
September 6, 2006 at 9:12 pm #187730pto
No you donβt you just do it though the door opening it dead easy
A five minuet job done loadsJack
September 6, 2006 at 10:11 pm #187731superfix
π π π π
September 6, 2006 at 10:43 pm #187732gegsy
Hi Jack
Front panel off everytime, why try and wallpaper the hall through the letter box :rolls:BTW Jack, are you a trade member in need of activation?? as you are advising in a public forum π If so please contact site admin. π
Curiosity, how long does it take to change door gasket without panel off?
GregSeptember 6, 2006 at 11:48 pm #187733Penguin45
You physically cannot remove and replace the door gasket on the clamp band machines withe the front panel in place – there is not enough room to get a driver in and working with it in place.
September 7, 2006 at 11:04 am #187734pto
I did apply for trade membership but got no reply
Anyway I thought that model had a spring
You donβt take the tub out of a zanussi do you
And if you can change one on a zanussi then these
Are easy like I say 5 minuetsJack
September 7, 2006 at 5:46 pm #187735Wizz
Gentlemen,
I am overwhelmed by your collective response and intrigued by the debate that its caused. It would be great to do this without taking the front panel off so I’ll give it a go… although I have to say it looks like I’ll resort to plan ‘A’. I’ll let you know how I get on!
WizzPS. For your reference the model number is WFX2867GB/01 and the gasket part number is 361127.
September 7, 2006 at 6:53 pm #187736gegsy
Yes that model does have a spring, but why would you want to struggle for the sake of 3 minutes to remove front panel, thats just making work for yourself πZanussi is a different ball game as the front doesn’t come off and you just have to struggle so no comparison really to the Bosch.
As for Trade Access a PM to either Dave_Conway or kwatt should be able to sort that out.
Greg π
