Replacing Water Level Pressure Sensor on Controller Board.
Home Forums Public Support Forums International Forums Australasian Appliance Forum Replacing Water Level Pressure Sensor on Controller Board.
  • #18843
    Number2
    F&P
    LW085F
    Yellow Motor Controller. Series 8 426119E
    Any F&P engineers here that know which suppliers catalog the pressure sensors came from ie where can I source one from.
    -After it was overloaded machine wouldn’t spin just stepping checks.
    -Traced fault codes to faulty Water Level Pressure Sensor.
    -No impedance change across all 4 pins tested in place at different hose pressures. I assume it is bung.
    I want to desolder and replace the component rather than the whole controller. I’ve put a bit of work into this unit; conformal coating, breaking off the circuit board support tabs that give track corrosion issues, re-anodizing the heat sink etc.
    #180638
    Re: Replacing Water Level Pressure Sensor on Controller Boar
    F+P will only supply the sensor as part of the control board – p/no 426204AP.
    Check your email BTW 😀 .
    Number2
    Thanks Penguin. Any where in NZ that repairs modules?
    #180640
    I haven’t an NZ contact, No2, I’m sorry. Mind you Oz is only 1000 miles away…… 😀
    Perhaps a raid on the tip or a word with a local repairer for a scrap board?
    If you do find a company to repair it, please let me know as this has cropped up a couple of times.
    Thanks and good luck,
