reprogramming a PCb on a hotpoint
Home Forums Public Support Forums Help And Support Washing Machine Help Forum reprogramming a PCb on a hotpoint
  • #82578
    I have a working Hotpoint wma50
    I have a board from a non working (in pieces) wma56
    I would like to reprogram the board to work in a wma42 ( I do not have this machine here)
    The boards are the seemingly the same – all 547 004 boards
    I have the push button sequence in order to reprogram
    If I put just power to the board using the power connections from the wma50, can I reprogram the board or must all the connections be attached?
    If all the connections must be attached, must they be attached as per the wma42 or is it sufficient to connect as the wma50?
    Or is it just not possible to program the borad to wma42 on a wma50?
    #420322
    Re: reprogramming a PCb on a hotpoint
    You will need to connect the board to the appliance you intend to programme. You cannot do it otherwise.
    #420323
    Thanks!
