Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › reset code for a beko wma 665 w
- This topic has 8 replies, 5 voices, and was last updated 17 years, 6 months ago by
terrygs.
September 20, 2008 at 8:34 am #39609
terrygs
ParticipantCan u help me, the LED keeps flashing on the main wash. Ive pressed the start and pause button at the same time and turned it on and 4 dashes comes up. if u press the start button on spin the letter H apears with 3 dashes. IF u press start on 90degrees wash all the buttons start 2 flash, if u press start it will begin to fill up, then everytime u press start it will go through every cycle and won’t stop. when u turn it off and then back on it will go back 2 flashing on the main wash again. Plz can anybody HELP ME its driving me crazy 😥
September 20, 2008 at 7:08 pm #262939smartin
ParticipantRe: reset code for a beko wma 665 w
this machine has a complex self diagnosis fault system, by pressing various combinations of buttons as it stands i dont think anyone will be able to tell what is wrong with it or at what stage of diagnostics it is stuck in. for any future readers of this post unless you know what you are doing dont press random combinations of buttons on pcb,s
September 26, 2008 at 9:14 am #262940terrygs
Participantive just had a engineer out from whitegoods index ……. whot a wast of time and money telling me the main board has gon. how can the board be gon when it goes through every cycle
September 26, 2008 at 5:26 pm #262941SparkyP
Hi Terry
When you use the test cycle does the motor rotate and go into Hi Spin…?
When you say it displays H then 3 dashes that means no fault found on components.Can you start it in normal mode?
Sparky P
September 27, 2008 at 1:47 pm #262942terrygs
Participanthi sparky.. when you use the test mode,it starts to fill with warter. you then have to press play to change cycle which is wash then spin and so on… but you carnt start in normal mode it just whont play
September 27, 2008 at 9:55 pm #262943cockney steve
Easily!….you have already said that it won’t follow through the cycle, but by prodding various buttons, you can get it to do things.
the board would appear to have a fault……as a rank amateur, I’d guess the EEPROM is dead……that’s the brain that tells each function when it has to operate….and it’s not doing that, is it?September 28, 2008 at 1:25 pm #262944SparkyP
I am afraid i think that it is the board too as it cannot diagnose itself..Quite a common problem in beko’s i’m afraid…..
Are you gonna price a board up or just throw the said item away…..A 665 is not that old is it not still under warranty?
Sparkyp
September 29, 2008 at 7:34 pm #262945terrygs
Participantthe warranty is up, as it is only 14 months old. Would u reccomend indesit WIB 111
September 29, 2008 at 8:25 pm #262946kwatt
Keymasterterrygs wrote:Would u reccomend indesit WIB 111
No will likely be the resounding answer to that one here. Unadulterated rubbish for the most part seems to be the general opinion of anything Indesit.
