Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Reset information required
- This topic has 7 replies, 4 voices, and was last updated 13 years, 8 months ago by
Allsorts.
July 29, 2012 at 6:35 pm #70695
Allsorts
ParticipantAnyone got the sequence for reset on a Bosch WAE24364GB/11
It has touch buttons on this one… not seen one of these before… F21, brushes were very low… changed the brushes but can’t reset the code.
Doesn’t react as normal as it has touch buttons.
George
July 29, 2012 at 7:01 pm #378718timdowning
ParticipantRe: Reset information required
The reset for this range is as discussed on here many a time. This range all have the touch buttons. It can be fiddly to get the reset to happen. And it has been discussed that the motor sometimes has to be disconnected for the reset to be successful. Personally I havent had to do that.
July 29, 2012 at 7:42 pm #378719Allsorts
Ok.. So are you saying that it is the normal 6 o’clock / 7 o’clock reset operation?
If so, at what point is the spin button touched, as I tried this for a good half hour last night and the machine was having none of it.
George
July 29, 2012 at 7:54 pm #378720timdowning
Turn dial to off position.
Turn dial to 6 0clock position.
Then hold spin button and at the same time turn dial one click clockwise.
Then release spin button.
Then turn dial to off position.(Dont forget to try it with the motor unplugged as well)
July 29, 2012 at 10:17 pm #378721Allsorts
OK Tim thanks…
Will try again tomorrow.. Just hope the little sucker works this time as it is not a local call.
George
January 8, 2014 at 1:20 pm #378722suedehead1
hi, i have tried everything with the same model to reset F21 but no avail. the touch buttons dont make a noise and it wont reset
suspect pcb any thoughts welcomedJanuary 8, 2014 at 2:26 pm #378723Martin
suedehead1 wrote:hi, i have tried everything with the same model to reset F21 but no avail. the touch buttons dont make a noise and it wont reset
If the motor brush failure took out the RCD/MCB when it packed in then it may have blown the motor triac on the PCB. Best check the PCB for surface damage in this case I reckon.
January 8, 2014 at 9:09 pm #378724suedehead1
thanks for the reply i will have anotherlook
