Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › RH8CTD701 Turning off after a few minutes
- This topic has 8 replies, 3 voices, and was last updated 7 months ago by
Tez911.
September 2, 2025 at 12:46 pm #103547
Tez911
ParticipantHi all i have a Russell Hobbs RH8CTD701, was working fine went on holiday and had niece looking after house, when we got back it was clear the filters had not been emptied so i cleaned it all out including the pioes that feed the the water collection at the top. But everytime i use it it stops after a couple of minutes. It will actually turn off then after about a minute the display comes back on. Have changed the heater assembly at the rear including all sensors attached to it. Any help would be appreciated i cannot afford a new dryer.
September 2, 2025 at 5:09 pm #493634kwatt
KeymasterStrange there’s no error code but here’s the service test stuff for it, you need to give it five seconds at least when changing through them.
September 2, 2025 at 6:55 pm #493635electrofix
Moderatorhave you checked the socket ?
try running it in a different socket outlet
September 4, 2025 at 12:01 pm #493636Tez911
Participantkwatt wrote:Strange there’s no error code but here’s the service test stuff for it, you need to give it five seconds at least when changing through them.
Where it says sw2? attached are the buttons I have on machine.
I have tried another socket with same results but the both sockets are on the same spur. Would it be safe testing through a extension?September 4, 2025 at 2:13 pm #493637electrofix
Moderatoryes as a short test you can use an extension lead. make sure its rated at least 10 amp and unwound
the way you are talking all the power goes off the machine ( no lights at all) for about 60 secs
does sound like a power issue. as soon as the heater comes on the power drawn by the machine heats something up that switches off the power
this can be internal or external to the machine , could even be the plug on the lead. have you checked that for signs of getting hot ?
September 5, 2025 at 10:22 am #493638Tez911
Participantelectrofix wrote:yes as a short test you can use an extension lead. make sure its rated at least 10 amp and unwound
Manage to get it in service mode, first thing to flag up was E05 and I ordered the sensor that sits just under the filter. Replaced today still same issue. The plug does get warm but wouldn’t say its too hot. I have replaced the lead and plug in the past as the one melted. I will try and test on another socket thus weekend. Thanks for the reply
September 5, 2025 at 1:59 pm #493639electrofix
Moderatorwhen you say you replaced the lead and plug is it a moulded plug on the new lead
if yes suspect that till you prove otherwise
you would have to do a continuity check on the lead after it failsDave
September 5, 2025 at 9:52 pm #493640Tez911
ParticipantYes it is a moulded plug, replaced like for like. Will hopefully get time sunday to check
September 7, 2025 at 2:05 pm #493641Tez911
ParticipantTested on extension today from another socket did exactly the same also checked continuity on earth live and neutral from plug to the suppressor filter on fail and all passes. Think at this point im going to pull pcb out and look for obvious damage
