AEG Favorit Sensor Logic F650 Vi needs topping up daily!- warning light tells us so and usually takes a fair amount to fill back up. Any suggestions please?
Lid gasket perished or complete dispenser unit needs replacing?
Using that amount of rinse aid each day surely would cause your machine to overfoam and leak as a rule? Either that or the rinse aid solution is leaking internally (between inner and outer door panels) and into the base of the machine? 😕
