Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › rinse problem with gw709nz
- This topic has 10 replies, 2 voices, and was last updated 19 years, 9 months ago by
tmd.
July 8, 2006 at 12:13 am #18989
tmd
Participantour fisher and paykel smartdrive9 excellence model gw709nz
is runing through the wash cycle but wen it gets to the rinse cycle the pump runs intermittently then stops and machine beep
error code is 00111110can anyone help with this
thanksJuly 8, 2006 at 8:16 am #181238Penguin45
ParticipantRe: rinse problem with gw709nz
Drain pump is drawing too much current. The fact that it cuts out and restarts suggests that is overheating and the TOC turns it off. Time for a new pump………
Be advised that there is a permanent live supply to the pump, as long as the plug is connected, so pull it!
Penguin45.July 8, 2006 at 8:37 am #181239tmd
would you have a part number for the pump?
July 8, 2006 at 6:00 pm #181240Penguin45
426956P is the one you want – worth pulling the present one to check there’s nothing tangled around the impellor or shaft, slowing it down. It’s a twist fit from underneath.
July 15, 2006 at 8:11 am #181241tmd
i have just replaced the pump and cleand out the whole machine but still getting the same fault code
is there a reset or should it just run throughthanks
July 15, 2006 at 4:13 pm #181242Penguin45
Fault code can be recalled for up to 8 operations after rectification – have you tried running it yet?
July 16, 2006 at 5:06 am #181243tmd
yea we tried it but still had fault but have since tried again and has worked fine
thank you for your help
July 25, 2006 at 8:55 am #181244tmd
we are still having problems with this machine its stoping at the rinse cycle and trying to pump but stopping the new pump hasnt realy made any difference and its still coming up with the same eror code
any help would be appreciated
July 25, 2006 at 11:01 pm #181245Penguin45
Does it actually drain the water?
July 27, 2006 at 7:52 am #181246tmd
when it gets to the rinse cycle it trys to pump the water and does in bursts but then stops and starts beeping.
if you keep restarting it when it beeps it eventualy runs through a full wash and the will be fine for the rest of the day.
but then the same problems the next dayis it time for a new machine?
July 27, 2006 at 7:29 pm #181247Penguin45
Run the diagnostics again and see what comes up. There are several recent threads with pumps cutting in and out with pressure switch problems.
