rl33 samsung
  • #45844
    robbo1973
    been out to this one as freezing in the fridge and found the baffle snapped off and the motor turning fine so no fault code.I had a spare cover on the van so changed just the baffle as this model has the single wire and mine was the older version.everything seemed fine when i left but after 2 days it is freezing up again when i went back the baffle is closed(i removed the rubber seal as normal) but when you open the fridge door the baffle norm rotates but it doesnt and the fan is running even when the fridge door is open,I thought it stopped can someone confirm this?.and if so what would cause the fan to run all the time module?
    cheers chris
    #287284
    lee8
    Re: rl33 samsung
    The fan runs all the time until the stat reaches temp and stops the fan.
    If fan is on constantly either there isn`t sufficent cooling in the freezer or the sensor is faulty.
    The cover should rotate when the door is opened/closed but the complete evaporator cover which contain the motor isn`t interchangable between the old/new as they changed the wiring.
    Otherwise the small motor is knackered.
