Rosieres 4040db Oven Temp accuracy
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Rosieres 4040db Oven Temp accuracy
  • #73719
    Sandy2v
    Can someone tell me what the accuracy should be on these ovens? i.e. +/- 10 {e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of control knob setting for example.
    Sandy 🙂
    #388601
    Re: Rosieres 4040db Oven Temp accuracy
    oven must be empty of everything and switched on for 1 hour at 200oc and there is tolerance of 10{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the max temperature.
    you have to note the temperature the thermostat switches off and on then cycle for about 4 cycles then add together and divide by the amount of cycles to get the correct average temperature.
    Ie on 200 0ff 220 on198 off 223 on 420 off 421 add 420+421 ±4 = 210oc which gives you the operating temperature. can’t find the divide key.
    Bryan
