Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Rosieres LV1980A dishwasher//Candy
- This topic has 10 replies, 4 voices, and was last updated 18 years, 1 month ago by
cornwell40.
February 21, 2008 at 9:32 am #34739
cornwell40
ParticipantIntegrated dishwasher has eaten the end of a steak knife which they knew was ‘looking a little iffy’ :rolls: .
Consequently this needs the circ pump and motor plus the two large diameter short hoses, one straight, ane angled, from and to the circ pump. Also require door switch. I know thy’re Candy but not sure if the motor is exactly the same.eTC
February 26, 2008 at 9:19 am #243835cornwell40
ParticipantRe: Rosieres LV1980A dishwasher//Candy
Oops 😳
Model is LVI980A
Product no. is 321851000TC
June 16, 2008 at 9:24 am #243836cornwell40
I hate this dishwasher. 😈 😈
The wash circulation continues at low power all the way through the wash.
Originally it used to go into a turbo setting soon after starting . Pretty sure its the board which controls it but anyone got info on these. 😕TC
June 16, 2008 at 6:36 pm #243837Penguin45
Module – 41001601 – from 0136
Module – 41001085 – up to 0136Something in your in-box.
June 16, 2008 at 10:29 pm #243838cornwell40
Thanks Chris
Most helpful 😉
TC
May 10, 2013 at 8:05 am #243839Simon46
Ive got one that circ pump has eaten something. How does the decor door come off?
S.May 10, 2013 at 8:10 am #243840eastlmark
ModeratorRe: Rosieres LV1980A dishwasher//Candy
if its normal candy stuff then its the small screws in the side of the door that need to come out then I think its an outward and upward lift of the door panel as its hooked in. Usually acompanied by cracking plastic noises.
May 10, 2013 at 10:32 am #243841Simon46
Thanks mate. Coudnt figure out what was holdin bottom of door to dishwasher.
S.May 15, 2013 at 11:34 am #243842Simon46
Any body got a wiring diagram as I seem to have a blue wire not connected to anything on the circulation pump. New pump has wiring going into the stator whilst old seized pump has a tacho and magnet on the end of it
May 16, 2013 at 10:35 am #243843Simon46
Old pump no is 91201406 new one 41031776. Tacho IS present on new one but on other side of motor. 3 pin connector plug appears to apply live to one side of the motor, the other two pins are for the tacho. There is a blue wire female spade hanging loose on the wiring loom of the dishwasher (may have fallen off) and the only place I can see it fitting is on the start capacitor(one blue wire and one red wire connected on each side of cap from stator) but I do not want to blow the speed control module up. can any body confirm where the blue wire connects?
Desperate
SimonMay 20, 2013 at 3:15 pm #243844Simon46
Wired pump up to mains worked out to which side of cap(blue wire going into stator). Fitted it 240 volts to new fitted pump but voltage drops when connected and pump hums(pcb fault but no serial no on dishwasher as two types). Also diverter valve jammed and door lock gone.
Wont be doing another!S.
