Rosieres Paul Bocuse
Home Forums Public Support Forums Spare Parts Help Rosieres Paul Bocuse
  • #89520
    sigriddixon
    HELP!!
    My right hand oven liner has corroded away, the fan grill and oven no longer heat up.
    The left hand oven only reaches a certain temperature and then sets the trip switch off! I love my oven, but the engineer I had come around has told me to write it off ( Not a fan of range cookers or Rosieres!!) Please let me know if I can save it! I live in Ross-on-Wye and as I am a giddybrained female on my own I will need someone to fix it for me too! I hope you can help! Thanks!!
    #441601
    kaibart
    Re: Rosieres Paul Bocuse
    All I can suggest is insure it with d&g and have the manufacturer out to it the parts are very expensive as they are made by the candy group
    #441602
    D&G will not cover it as it is over 15yrs old. Yes it can be repaired by an engineer who knows or is prepared to work on one but most run a mile.
    Left hand oven would normally be the base element ( simple repair ) Not sure what you mean by fan oven as that is also on the left oven.R/h oven is a standard convection oven (top & bottom element).
    Left hand oven dependent on its variant is grill,grill with fan,convection oven, or fan oven with grill.
    Dependent on how long your prepared to wait depends if I can do it when I am out of my normal area closer to you.I hold the parts in stock.
    Bryan
