Rosieres Paul Bocuse 2040 DB cooker
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Rosieres Paul Bocuse 2040 DB cooker
  • #77274
    Jane Hillyard
    Help please! I have just moved into a house with this range but neither ovens work. Neither does the ignition for the gas rings. Is it likely that I need 2 new elements or is it more complex than that? Thanks in advance, Jane
    #401606
    SAMURI
    Re: Rosieres Paul Bocuse 2040 DB cooker
    Most likely you have an isolator switch switch for the mains power to the oven.
    If you have mains power to the oven then check you have a time set on the oven clock.
    Bob
    #401607
    This one doesn’t have a clock 😛
    But yes it sounds like a no power problem.
    Bryan
    #401608
    SAMURI
    I do not see any of this make or model in my area so just gave general advice.
    Well clocked Brian. 😆
    See you Thursday
    Bob
