Routeplanner/measuring tool
Home Forums General Trade Forum Routeplanner/measuring tool
  • #9796
    Tubs
    Hi all
    I’m sure youve all used AA routeplanner etc. But found this useful little routeplanner website. Not so much that it gets you from A to B but the distance tool is excellent, even can measure the length of ya road.
    Just select your “to and from” and let the planner do the rest. Then on the toolbar click the ruler and then click and drag for your distance radius. Takes a bit of driving but its worth a play.
    http://www.uk.map24.com/
    Steve
    #135878
    Re: Routeplanner/measuring tool
    A good investment is Microsoft Autoroute as you can punch in multiple destinations to that and play with the order in which you arrive, calculating the most efficient route pretty easily. All that’s needed to do that is a postcode or a street address, a very useful tool.
    Even more useful, if the budget stretches, is Mappoint, which also gives demographic information as well as postal sectors, districts etc. as well to boot. Not so cheap though. 😕
    Latest version of autoroute I have and use it every day to work out my routes for the day/week which helps when booking in calls.let me know if you want to see it.. 😉
    Map point I am working on getting a copy which should arrive early next week.If anyone wants to ” look at it ” hmmm.. 😉
    bryan
    #135880
    Alex
    Take a look at this one. Best I’ve found, will save all your searches, reverse facility, and you can highlight maps for each step of the journey if you wish.
    http://www.mapquest.com/maps/main.adp?country=GB
    Alex
    #135881
    superfix
    Wish someone would send one to our office 😈
    #135882
    boro wrote:Wish someone would send one to our office 😈
    Call centres… not a clue about geography (or much else in many cases ;)).
    superfix
    How true 🙄
    #135884
    andy_art_trigg
    Is there any software that’s as good as Autoroute 2005 but can handle multiple engineer’s runs and take into account timed calls?
    #135885
    ANDY
    you can save the different days and add the postcodes as and when you have them.
    we have MON – FRI and then for instance mon 8th or tue 9th
    all you need to do is put the engineers name in front or last and as the day ends clear the route off and save for the following week.
    bryan
    #135886
    andy_art_trigg
    What about if you had say a dozen or more engineers and a very large area? Is there software that can have say over 100 post codes for jobs booked in on a particular day and divide them efficiently amongst the engineers? I reckon specialist (very expensive) software would be needed to cope with that.
