Hi all!
I’ve seen a few people have the same issue but couldn’t find anything recent.
I have the RS20CCMS Fridge Freezer and the freezer started to lose temperature and food started to defrost.
I found a post on here that said to remove the back panel and defrost the block with a hairdryer which I’ve done three times and its working each time.
It’s great that it works like that but I would rather fix it permanently now 🙂
On this last time it has happened, the fridge temperature flashed so I turned it off at the wall, turned it on again and it has now stayed at 17 degrees.
Any ideas?
Thanks!
Re: RS20CCMS Samsung Side by Side Fridge Freezer – Slight fa
Hi again. The defrost sensor has been replaced but unfortunately it is back to square one again 🙁
The fridge is flashing again on the display and the fridge is not cold again.
It worked as per usual for around a week after replacing the sensor but it obviously isn’t the answer.
Any ideas on what is next?
Check the thermal fuse to see if you have a circuit ( Red & Black Wires ) if you have a circuit then the fuse is ok and it will be the defrost heater. If you have no circuit on the fuse it will be the fuse.
Both of the heaters are clear of ice when I do the whole defrost thing so I guessed that the heaters must be ok. I’ll check the thermal fuse and see what happens!
Thanks for the advice!
