i took the freezer cover to defrost alongwith sensors then i put back the sensor wires and the cover as well. when i switch it on, there was only small line was there on the display. i did waite for 10-15 min but the display was doing the same.so what could be the problum?
depends on where the line is as it is a fault code but if the line was not there before then you aint plugged something back in prob the air sensor blue wires behind cover very short easy to forget.
