RSH1DTMH Defrost Problems
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum RSH1DTMH Defrost Problems
  • #67460
    overthetop
    Have a defrost problem in the RSH1DTMH fridge compartment.
    Poor cold air temperature circulation in the fridge due to icing up behind back panel and requiring the occassional manual defrost.
    I am aware that the RS21 has similar issues, electrical parts can be checked and be replaced where faulty.
    I believe that the RSH1 defrost parts are different.
    Last time I did a manual defrost I noted that the defrost heater had what look like to be two sensors.
    There are 4 electrical plugs; 2 for detachable fan panel; 2 more in the area of the evaporator behind the fan panel.
    Can anyone please tell me the resistive values I should expect to measure with a multimeter at each of the plugs(detached) for each of the items?
    thanks
    #367510
    Re: RSH1DTMH Defrost Problems
    So far as I know the RSH series suffers from pretty much the same problem. It just hasn’t starred on Watchdog.
    Bryan may have the values for you if they’ve ever been published (not unusual that they aren’t) but, I suspect, replacing the panel etc will be the only way to cure it.
    There is a modified heater and modification sensor ass and updated evap panel for the RSH1 range that I can supply.
    Samsung@ffrservices.co.uk
    Bryan
