RSH1DTMH. S/N 891542BQ700360
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries RSH1DTMH. S/N 891542BQ700360
  • #78163
    Alanj
    Hi guys, above American f/f has stopped dispensing water. It is still making ice. I thought the solenoid valve had maybe gone, but no. I think the tube between the valve and the door must be freezing and stopping the flow of water. Where is it likely to do this and is there a cure?
    Alan
    #404699
    Re: RSH1DTMH. S/N 891542BQ700360
    New door
    #404700
    SAMURI
    Pre cooling tank in fridge frozen.
    Tank is behind bottom baskets in fridge.
    Bob
    #404701
    Thought he had already checked that
    Bryan
    #404702
    Alanj
    Hi Bob, if the pre cooling tank is frozen what’s the remedy? I got the customer to switch off freezer over weekend and then try it again. They had water for a short while.
    Alan
    #404703
    SAMURI
    Get the customer to turn it off for a couple of hours with the fridge door open or.
    Turn it off and warm the tank with a hair dryer keeping the hair dryer moving and not in one spot for 5 mins.
    Then turn it back on and dispense a couple of litres of water.
    if the problem returns then it will be a rear panel or defrost fault.
    if it is less than 5 years old Samsung has extended the warranty to 5 years
    Bob
    #404704
    Alanj
    What do you mean by rear panel? PCB?
    Customer said it was working ok up until he changed the water filter? Coincidence?
    Alan
    #404705
    SAMURI
    The rear panel in the fridge behind the water tank as the insulation fails.
    Bob
    #404706
    Alanj
    Ok thanks Bob
