RSH5PTTS1/XEG
  • #71863
    Dragan
    Side by side Samsung,model RSH5PTTS1/XEG
    I have changed compressor by original one but it can not start-just moves for a second.The red LED on the inverter control board flashes three times.I have dane all tests from user control board but compressor can not start by force.No errors on display.
    Any advice?
    #382608
    Re: RSH5PTTS1/XEG
    try to pm R600a he has access to samsung info
    Dragan
    Re: RSH5PTTS1/XEG
    Thank you,
    Re: RSH5PTTS1/XEG
    I have no idea why you would be changing a compressor on a RSH5 as they are still covered under warranty by samsung.These compressors are very reliable and would suspect that it would be something else rather than the compressor.
    What was the fault and your e-mail address ?
    Bryan
    #382611
    lee8
    Re: RSH5PTTS1/XEG
    OOOOOpppppssss, I’d say the issue is in the Board not the compressor. Check supply to it though, just in case the comp is jamned.
    Expensive mistake.
