Running Costs of Hob – Ceramic v Induction
Home Forums Public Support Forums General Enquiries And Questions Running Costs of Hob – Ceramic v Induction
  • #35618
    danktuft
    Hello,
    I’ve been looking around for info on this and am getting conflicting advice, could anyone on here help me? I’d like to know which style of hob uses most electricity – induction or ceramic/halogen? Thanks for taking the time to help.
    #247357
    greaseater
    Re: Running Costs of Hob – Ceramic v Induction
    Hi there,
    Easy one to answer…
    Induction is the most efficient hob on the market and is even more efficient than a gas hob. The reason for this is that there is no heat transfer through the glass and the contents of the pan are heated by a magnetic field.
    The hob only works when it is put into contact with a special pan and switches off automatically when it is removed from the zone.
    The other benefit is that you cannot burn liquids on the glass as it does not get too hot which means that the glass will not mark.
    The best but not cheap.
    Greaseater.
    #247358
    danktuft
    Greaseater,
    Thanks for the rapid reply, it’s very helpful. Could you clarify just a little further? I’d like to know roughly how much cheaper (or less energy they use) than ceramics an induction hob is. Of course, I don’t need to know exactly just ball park, eg 20{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} less energy used.
    #247359
    greaseater
    Not too sure but I do know that induction hobs are usually between 70/78{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} efficient, which is better than ceramic and gas.
    Safer with kids as the hob does not get as hot as a normal ceramic.
    Cheers,
    Greaseater.
    #247360
    danktuft
    Thanks Greaseater, I phoned up the Siemens support line, they told me this:
    This is the advice I was given about halogen v induction. The time taken to take 2 litres of water from 15 degrees to 90 degrees:
    Halogen: 8.6 minutes
    Induction: 4.7 minutes
    The energy efficiency, which I think is how much of the power used is actually heating the water:
    Halogen: 56{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}
    Induction: 80{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}
