Hi all, I have a Russell Hobbs RH8CTD701 condenser dryer that is leaking underneath, and not filling the water tray up. I’ve cleaned out a load of soggy junk from under the pump, and rinsed the pump out. I filled the channel up with water so the float raised to the contact and switched the machine on. it worked fine and pumped the water to where its supposed to go!
Put a load of washing in but it is still leaking and not going through the pump, so where/why could it leaking?
Thanks in advance,
Lee
