Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Russell Hobbs RH8CTD701 belt replacement advice
- This topic has 4 replies, 3 voices, and was last updated 2 years, 1 month ago by
giveitago616.
February 10, 2024 at 11:25 am #102579
giveitago616
ParticipantHi all, I have the above model of condenser dryer. The belts gone, I have a replacement arriving today (hopefully!). I’m not the most technical when it comes to fixing it, but I’ll try. Has anyone any tips or videos as to the best way to go about it please? Not sure if I should attempt putting it over from the front or the rear.
Thanks in advanceFebruary 10, 2024 at 6:01 pm #489539andyjawa
ParticipantWell not familiar with that particular model and so never changed a belt on one and very little info available so it seems; was hoping for a sales photo of the rear of the machine to see if it a rebadged machine I`ve worked on before but no luck.
On most if not all condenser tumble dryers you attempt to replace a belt from the back. Typically this will mean removing the heater cover screws to gain access to the drum bearing to remove it. With the lid off and right hand side panel off (if looking from the front) you may have to remove the actual rear back screws to allow movement to dangle new belt down passed the back of the drum and drum bearing shaft then over the drum. The golden rule is to avoid dismantling as little as possible. Then moving to the r/h/side refit the belt. Bound to be a jockey pulley – belt tensioner and that will require removal of the fan cover to get to the motor`s shaft pulley. Can`t tell you anymore I`m afraid.February 10, 2024 at 8:31 pm #489540electrofix
ModeratorIts build by a company called vestel
by the looks of it you will have to remove the motor to get the belt around the motor shaft
thats after you find a way to get the belt around the drum
February 12, 2024 at 3:36 pm #489541giveitago616
ParticipantBrill, thank you. I’ll give it a go if the belt turns up. Seems royal mail have it, but they’re a bit slow delivering!
February 17, 2024 at 3:31 pm #489542giveitago616
ParticipantAll fixed! Thanks all, yes Dave, had to take the motor out to slide the belt under. The brackets on the motor are a bit fiddly to get to, but all done now, and seems to be running okay. Drying a lot better as well it seems, gave it a good clean out. Its amazing how far all the fluff gets over time.
Thanks again,
Lee -
