S25B-RSS31 – how to remove door with water pipe?
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum S25B-RSS31 – how to remove door with water pipe?
  • #45202
    Graphite
    I have a whirlpool S25B-RSS31 fridge freezer and I need to remove the doors to move it.
    There is a water pipe running through the middle of the lower hinge on the left hand door – how do I disconnect it?
    Thanks 😆
    #283996
    Re: S25B-RSS31 – how to remove door with water pipe?
    Not familiar with that specific model but most would have a push-fit connector on the pipe somewhere around the point where the pipe enters the door so you can release the pipe to remove the door.
    HTH
    Dales-Electronic
    Remove bottom kick-strip and as Ken says disconnect water supply pipe at ‘push-fit connector
    #283998
    Graphite
    Thanks – that was spot on 😀
    A bit tricky to get the thing apart in that position LOL 😆
    I will post some pics later incase anyone else has the same problem.
    I took the opportunity to remove a few ‘skip fulls’ of dust and fluff out of the thing whilst i had the kick panel off 😳 😆
    Thanks guys! 8)
