This appliance has a fault code of F1 which is I believe a blocked filter. This was replaced. The appliance was switched off for an hour to reset the fault as per the user manual. The fault is still indicated and the ice machine will not work. The cold water function operates fine with a plentifull supply of water. Any help with this would be appreciated.
