just changed the drum bearings on my Zanussi 1050 washing machine. Unfortunately I have found a wire clip thingy left over which i now recognise as being attached to the element! Im wondering if its safe to keep using the machine without this? – (Its working fine) I guess its there to stop any possibilty of the element touching the inner drum?
If its likely to cause a problem, is it possible to refit without splitting the whole drum again? :boops:
There is a danger of the heater getting caught by the drum. You may be able to fit it by removing the heater and using some long grabber and do it that way
