salt etc in table top dishwashers
Home Forums Public Support Forums Help And Support Dishwasher Help Forum salt etc in table top dishwashers
  • #29243
    skoop
    trilobyte wrote:
    If using a tabletop machine, USE POWDER DETERGENT, and separate Rinse Aid. Use salt in a ‘hard water’ area.
    Tablets of any type are too concentrated for these machines, and will cause overfoaming with detrimental results to cleaning performance, and possibly the machine (flooding).
    Hi, this is a quote from another thread. It lead me to wondering whether I don’t need to use any salt at all as I live in a soft water area – or should I still use a bit as in the manual?
    Also can you recommend brands of the powder detergent and rinse aid? Thanks. Is Finish a good brand for the salt? (if I need it.)
    #222466
    Re: salt etc in table top dishwashers
    skoop wrote: or should I still use a bit as in the manual?
    That’s the way to go..! :rtm:
    skoop wrote:Also can you recommend brands of the powder detergent and rinse aid? Thanks. Is Finish a good brand for the salt? (if I need it.)
    Finish is just fine for your machine :tup:
    #222467
    skoop
    Thank you, martin.
