Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › salt left on crockery
- This topic has 10 replies, 4 voices, and was last updated 20 years, 5 months ago by
gixerk1.
October 24, 2005 at 9:00 am #12760
gixerk1
Participanti have a neff s484oxo/gb/06 and have found my wife has been forgetting to fill the salt container i put 2 scoops in as recommended in the manual but i feel it needs more to start with and then regular topping up the refill light seems to come on after a couple of uses and i have a slight salt bloom otherwise it works fine any thoughts please
timOctober 24, 2005 at 9:09 am #151509Martin
ParticipantRe: salt left on crockery
Carefully check the salt lid gasket and that it fits snugly in position. Always use salt granules and when full with salt, should last 15 to 20 washes before the salt light comes on again 🙂
October 24, 2005 at 2:45 pm #151510gixerk1
thanks for your prompt reply i filled with salt none remains visable and i have turned the regulator to its lowest position but still get a salty residue is there some form of regulator that could be faulty im pretty sure the gaskit is working ok
thanks
timOctober 24, 2005 at 3:15 pm #151511Martin
The Softener Unit may be at fault in that case and need replacing?
Try running a full wash cycle empty, then try again with a normal load. If you have problems still, its the Softener Unit I’m afraid 🙁
October 24, 2005 at 3:25 pm #151512Washman
Do you mean a white residue on glasses etc, this can be caused by several things . are you using 2in1/3in1/4in1 tablets or individual powder/salt/rinse aid are spray arms rotating freely are you using the correct dose of detergent for your machine
Mike
October 24, 2005 at 3:53 pm #151513gixerk1
thanks again we do use rinse aid and tablets and after they have run out i will
move to seperete items my gut feeling its the water softner i dont know how it works or were it is but i filled up with salt this mornin and i could fill up now
if i had any it seems to just go after one wash i cleaned the gaskit and around that area
tim
i could not see a softner on the neff schematics would you be able to tell me where it is locatedOctober 24, 2005 at 4:06 pm #151514Martin
gixerk1 wrote:i could not see a softner on the neff schematics would you be able to tell me where it is located
Its the whole ‘Water Inlet Unit Part No: 208696 Cost =£128.08 + P & P 🙁
October 24, 2005 at 5:59 pm #151515gixerk1
Participantupdate
after another wash the glasses are almost perfect rinseaid on three salt on 1
im still at a loss to know why this is i must have put about 1 kg of salt in could this have been the problem or has it recharged the softening process
timOctober 24, 2005 at 6:55 pm #151516Martin
ParticipantRe: update
gixerk1 wrote:after another wash the glasses are almost perfect rinseaid on three salt on 1
im still at a loss to know why this is i must have put about 1 kg of salt in could this have been the problem or has it recharged the softening processTim,
Bit difficult trying to translate what you are on about here?
But do please bear in mind that dishwashers do need salt in order for the water softener to function correctly. If you are using 3 in 1 tablets, you still do need to use the water softener and regularly put SALT in it!
October 24, 2005 at 8:48 pm #151517gixerk1
sorry for being vague i put no1 on the salt dispenser i know you cant just use tablets i was wondering how much salt would be needed to fill up after not being filled for a long time
the marks seem to have gone but this was after a couple of washes do you think it has just settled down after being filled with salt
timOctober 24, 2005 at 10:58 pm #151518clivejameson
Yes…the softener may have been completely exhausted in which case it will take a wash or three to regenerate fully after adding the salt.
I suspect the deposit on your glasses was actually limescale from the water, the softener will now deal with this.
It’s worth reminding that the machine requires soft/softened water to achieve a good result so the components are deisgned to with this, and not hard water which will not only give a poor result but will actually damage the machine in time.
