samsung 12kg inverter belt drive model
Home Forums Public Support Forums Help And Support Washing Machine Help Forum samsung 12kg inverter belt drive model
  • #95622
    andyjawa
    Samsung model WF1124XAC/XEU01.
    Problem is the potted main pcb ( the one at the top ) fuse has blown which means that unless I can replace this which will not be easy I will have to buy a new pcb. However I need some pointers as to why the pcb fuse blew. Are there any common components that cause this? I notice that revolving the drum by hand is a little stiff but if I take the belt off the drum spins freely, I am not sure but the motor ( inverter type ) I think that this is normal. The main thing is I do not want to replace the pcb only for it to go pop again.
    Any ideas please?
    #460893
    andyjawa
    UPDATE. Sussed the cause. That motor that was stiff was the cause of the pcb going wrong. ….I think!! Went to somebody elses Samsung, 8 kg model, for something unrelated ( a leak ) the next day and as pure luck would have it it had the same motor fitted, it spins by hand very freely so presume that was the cause of pcb fuse blowing up as per the one as above. Note whilst searching for the under 10 year part warrantied motor it was listed as …….obsolete. Surely that is wrong even for a ” Shamshung “?
