Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Samsung 2028 Water Tank replacement
- This topic has 7 replies, 4 voices, and was last updated 17 years, 10 months ago by
Craigd.
June 6, 2008 at 7:45 pm #37227
Craigd
ParticipantMy water tank at the bottom of the fridge sprang a leak, i have a replacement but how do you fit it.
June 6, 2008 at 9:54 pm #253938admin
KeymasterRe: Samsung 2028 Water Tank replacement
The front grill at the bottom of the appliance needs to come off and behind that there is a push fit connector which you disconnect,there is a insert in the end of the pipe to stop leakage so dont loose it because you have to fit it to the new one.
At the back remove the metal grill assembly,”POWER OFF FIRST :nike: “.The water valve needs to be removed and the pipe disconnected,you can then pull the pipework out from within the fridge section.Refitting is the reverse of above.
Bryan
June 6, 2008 at 10:22 pm #253939Craigd
ParticipantRe: Samsung 2028 Water Tank replacement
thanks Brian, i’ll try it tommorrow.
June 6, 2008 at 10:32 pm #253940gegsy
Longest of the pipes from the tank goes to the door connector/front outlet and will need cutting down slightly 😉
June 9, 2008 at 11:28 am #253941Craigd
Okey, i’ve had the back panel off ond can see the pipe were it goes into the fridge… not a problem. The pipe to the front connection has me confused, i have take the plastic cover of the bottom ond can see the quick fit connection, but how do you get the pipe into the fridge, it goes through the metal and i cannot see how this metal cover comes off.
help please.
Cheers
craigJune 11, 2008 at 7:11 pm #253942Penguin45
Craigd wrote:I have got a leak on the water tank so have got a replacement but whats the best way to get the new pipe out of the front, the pipe to the rear is okey but to the front it goes throught the bottom of the tank and imerges through the hole behind the front grill before being connected to the quick fit adapter.
whats the best way to get the pipe from the bottom of the fridge to the front of the grill.
Cheers
CraigJune 12, 2008 at 3:14 pm #253943Craigd
Unpluging it is easy……. how to you feed the pipe through the front panel and get it to appear inside the fridge when there about 12 inches of in accessable void and a 90 degree turn.
June 12, 2008 at 4:57 pm #253944gegsy
Pipes feed from fridge cavity; one will appear near to compressor cooling fan (make sure you keep it well away) and the other will materialise just below both doors after removing the grill (longest of the pipes attached to new tank)
Thats all you need to know to do the job 😉Greg
