Hi all
I’ve had the 2029 for about 4 years now and last year the door display panel starting flickering and beeping. I stripped it out and the was condensation running into the connector plug from the ice maker. Anyway, I cleaned it up and refitted it and it has been fine since then – until yesterday.
Same problem – and I think the bizarre behavior is down to the moisture in the plug. I’ve cleaned it out – but I think the actual male plug (multi wire) may have corroded inside – so the contact isn’t good.
Questions are, where can I buy a new connector and the wire ends to plug in? If I wanted to buy a new control panel (display) – part DA41-00020 – where should I look?
Thanks in advance
Simon
The connector isnt available as a seperate part,it comes with the complete door.
Normally by replacing the PCB it will clear the fault,I have them in stock,send me an e-mail r600a@hotmail.com with the full model number and serial number.
