Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Samsung American Fridge Freezer RS21DCS No water dispensed..
- This topic has 8 replies, 5 voices, and was last updated 19 years, 7 months ago by
emmafish.
September 7, 2006 at 9:57 am #20653
emmafish
ParticipantHi all
hope someone can help me fix my fridge/freezer water dispenser. The icemaker works fine but depressing the water paddle, and no water is dispensed. I’ve turned the fridge off for 24hrs to thaw out the water tank, checked the micro-switch on the paddle and that looks fine. I guess I’m looking at the two water solonoid valve at the back rear?
regards
BobSeptember 7, 2006 at 6:17 pm #187872Dales-Electronic
ModeratorRe: Samsung American Fridge Freezer RS21DCS No water dispens
Bob – To reiterate, water passes from the inlet valve thro the water chiller behind the draws in the fridge and up to the dispenser via the bottom of the door. If you take off the joint below the door and then press the water lever this will tell you if water is coming thro from the valve via chiller.
September 8, 2006 at 5:47 pm #187873emmafish
ParticipantRe: Samsung American Fridge Freezer RS21DCS No water dispens
Thanks for your reply.
Removed the lower grill with the 3 screws and found the water pipe connector. removed the pipe and no water flowed when pressing the paddle.
What would be my next move?
regards
BobSeptember 8, 2006 at 8:17 pm #187874mayamay
This is exactly what happened to my fridge, see if the water tank inside your fridge is frozen, if it is, thats because the fan is freezing up and not circulating round , read my posting.
September 8, 2006 at 8:45 pm #187875emmafish
hi
how do you remove the pipes from the storage tank so i can let it defrost?
We’ve never had any fan noise, but I’d like to to check it, would it be behind the water tank?
Regards bobSeptember 14, 2006 at 7:54 pm #187876gegsy
I wouldn’t worry about the water dispenser at the moment.
I would concentrate on the bigger fault of the excess ice around fridge fan manifold.
Its more of a symptom and cause, you sort the manifold fault out (re below) and defrost appliance for 24hrs then all should return to normal.
There is a part change for this panel c/w fan motor unit which they have modified the drain hole to alleviate this fault re occuring 😀Greg
September 25, 2006 at 12:31 pm #187877emmafish
Think I’ve found the fault, It’s the water solonoid valve!
As you know the water splits into two valves, one for the ice and one for the water, the ice one measure around 1500R and the water one is open circuit. How could I, joe-public get a replacement?
Many thanks for you advice in the past.
regards
BobSeptember 28, 2006 at 7:30 pm #187878expertcat
ParticipantITS VERY UNSUAL FOR THE SOLENOIDS TO FAIL NEVER HAD 1 IN 7 YEARS YET.
SUPPOSE THERE MUST BE A FIRST.
September 29, 2006 at 1:13 pm #187879emmafish
Hi all
Fitted the new valve today (£50) all’s fine, thank you all for your responses I’ve learnt a liitle more about domestic appliances!
Many thanks
Bob -
