Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Samsung american style Rsa1utmg defrost issue please help!!
- This topic has 4 replies, 3 voices, and was last updated 9 years, 5 months ago by
azza111111.
October 27, 2016 at 7:22 am #89699
azza111111
ParticipantHi guys,
I’m new here and really hoping someone can help me troubleshoot a defrost issue with my Samsung rsa1utmg
From being turned on the fridge and freezer get down to there target temperatures of -20c and 6c.
After a few hours pass the temprature has risen dramatically. Turning on and off reset things and it gets back to its targets and the process repeats.
What I’ve tried/checked.
The freezer defrost heater fuse (behind evap coils) has continuity.
The freezer defrost heater element reads ok with a meter and I’ve ran it direct from a 240v supply and it heats up.
The evap coil sensor that is directly mounted to the coils has continuity.
Compressor fan and freezer cabinet fans both run.
I’ve checked resistance of all thermistors that I’ve found and they seam within range.
I looked at the control board o top of the fridge/freezer and located the plug for the defrost heater.
The black wire had 240v but the brown had nothing.I don’t thing the defrost heater is being told to come on. Can anyone shed any further light on this issue?
Oh also the display temperatures are wrong after the fridge/freezer has warmed up as are still say minus, around -35 if Iirc but are perfectly accurate after unit is turned off and back on.
And it would apear that the compressor doesn’t shut off unless I force a defrost or turn off. The set point was -20c and it was at -26c when I turned it off.(according to the display)
Thanks in advance Aaron
October 27, 2016 at 9:13 am #442221admin
KeymasterRe: Samsung american style Rsa1utmg defrost issue please hel
Firstly change the defrost sensor. Yellow wires with either a white or black bullet end.
Then see what it does overnight but be aware that it only goes into defrost every 12-14 hours.
Bryan
October 27, 2016 at 1:48 pm #442222azza111111
ParticipantRe: Samsung american style Rsa1utmg defrost issue please hel
Thanks Brian
Is it the sensor that’s strapped to the evap coil or the one that’s connected in line with the heater? ( size of a chocolate rolo) Thanks
October 28, 2016 at 6:07 am #442223azza111111
Hi Bryan,
On the heater itself there’s a little rolo shaped switch/sensor. Is it worth checking that or not as the heater ran via that with a direct 240v feed.
I will purchase a defrost sensor as per your previous suggestion.
February 3, 2017 at 5:58 pm #442224rbartlett
Chaps rather than start a new thread I have tagged onto this
I have one of these where the ice dispenser screw does not turn so nothing gets to the front door.
I suspect the motor has siezed but does anyone have a service manual so I can go armed and ready
TIA
Richard
