Hi All
I have the above make of washing machine and currently when it reaches its draining stage it makes a grinding noise and no water drains from the machine at all.
I have cleaned the debris filter and checked all pipes including the waste pipe and can find no blockages.
The Drain pump itself has a propeller on it which is very loose, however still attached. It does move from side to side and in and out (if you get what i mean). Could this be the noise or could it be the bearings inside the motor?
Any advice would be gratefully received as would be where i can purchase new pump if required!
Cheers
Motty999
