Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Samsung BF641FST Blank Display
- This topic has 4 replies, 3 voices, and was last updated 14 years, 5 months ago by
johnnyhoz.
November 1, 2011 at 8:46 pm #66011
johnnyhoz
ParticipantHi saw this oven today it has a blank display and no control the only life is the oven fan runs, I have 240v to the display board.
Is there a seperate control board or is it a dual board
I would be greatful for any advice, also aparently there is a version 1 and a version 2, got the rating plate details but nothing looks like it helps
JohnNovember 1, 2011 at 9:17 pm #362728admin
KeymasterRe: Samsung BF641FST Blank Display
How many wires is on the connections..It will be the PCB and or the thermal cut out on the duct.
Bryan
November 2, 2011 at 6:25 pm #362729johnnyhoz
ParticipantRe: Samsung BF641FST Blank Display
will find out how many wires when I go back tomorrow I also check the thermal cut out
November 15, 2011 at 4:34 pm #362730Pigpen4
I went to one of these back in July, with the same fault.
BF641FSTP/XEU Ser No 18157DDQA00386ECustomer had had it on max heat setting, so I reset the one-shot and it worked fine, … until yesterday.
I’m assuming the fan control stat to be at fault, but want to replace them both, instead of resetting the one-shot again.
I’ve got Connect pt no 5045176298306 for the fan stat, and 5045175177398 (from a thread on BF641fb) for the one shot.
❓ . Are these the right ones for this model, please?
❓ . Could anyone supply me with some tech info on this model, please?
Thanks,
Pigpen.November 23, 2011 at 9:12 pm #362731Pigpen4
Pigpen4 wrote:
I’ve got Connect pt no 5045176298306 for the fan stat, and 5045175177398 (from a thread on BF641fb) for the one shot.Well, I fitted these and now there’s life back in the control panel, but the cooling fan is on permanently – the replacement fan stat is closed circuit, as was the original one. It was just the one-shot at the back left corner that was OC.
I had thought that the fan stat should be Normally Open, and close when it needs the fan on, but on disconnecting it to simulate OC, the display goes dead again. That stat’s not what I thought it was, then !! :boops:
Any suggestions, please?
Thanks,
Pigpen. -
