Samsung BF641FST fault
  • #59646
    Allsorts
    Before I go out to this cooker this afternoon I thought I would check with you guys….
    Customer says that when they turn the knob the oven light comes on and so does the fan, but there is no heat… Apparently, they have had an engineer from Mold call out to check the element and he has told them the element is fine… (Sounds dodgy to me.. why check the element but not the whole cooker?)
    Nevertheless, Element, Thermostat, Regulator … Does anyone no the parts numbers for these please. Also, is the thermostat part of the regulator on these cookers?
    George
    #339045
    mirmay
    Re: Samsung BF641FST fault
    All electronically controlled. Check your emails, hope it helps.
