Hi there,
Is there a way to adjust the oven temperture on the Samsung CE 103V Combi Oven ??
When it’s set to 200 degrees C the actual oven temperature is only 150 degrees C.
I’ve had the cover off, found the temperature sensor but can’t see any potentiometer or whatever to adjust the temperature.
Hope you can help
Paul Chapman
