Samsung dishwasher 4c error
  • #101761
    funkyboogy
    MODEL DW60M9550BB
    when you start any prog it will pump ok for a couple of mins – then when it should be filling 4c error
    The water is switched on , it does have an aqua stop fill hose, I’m kinda assuming it could be this
    any advice appreciated
    thanks, Ally
    #485969
    well you would need to access the wires to the inlet valve and check for coil resistance first
    if yes then you would need to see if the unit energises the valve
    and go from there
    funkyboogy
    cheers Dave –
    will check this
    #485971
    kaibart
    I would check k the pump for any restrictions and you will hear pump run
    #485972
    funkyboogy
    update – it was the aqua stop hose ,
    thanks for the replys
    Ally
