Samsung dryer dv90t5240aw/s1 3c error code
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung dryer dv90t5240aw/s1 3c error code
  • #103552
    DPDOM
    This dryer is working for a while then makes a loud noise and eventually the error code 3C appears.
    I called a few days ago and removes a stone from the front of the drum but the problem is still there.
    I need to call back once they have removed the radiator for me to pull the dryer out but was hoping for any advice before I call.
    It looks like motor, pcb or wiring may be the issue.
    Regards
    had a few of these where the motor had dropped and caused the rear fan to rub on the fan housing
    there is no cure. motor mounts only come with motor and did not know if it was chassis that has warped. both customers decided to scrap it
    DPDOM
    Thank for the reply.
    Yes I’ve had a few with the motor mount and I’ve had success by putting some screws through the bottom of the plastic mount which is enough to lift the motor and fan slightly.
    I called back today as they have now removed the radiator and checked everything I could and all seems fine.
    The error code no longer comes up but after about 5 minutes the drum stops turning and a few minutes later the compressor stops but the display says its still working.
    I’m going to go for the Top large pcb and will report back.
    Fingers crossed.
    #493672
    DPDOM
    It was the large inverter board.
