Samsung Dryer WT46E381GB/46 – No heat Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Samsung Dryer WT46E381GB/46 – No heat This topic has 5 replies, 2 voices, and was last updated 7 years, 5 months ago by asp11. Viewing 6 posts - 1 through 6 (of 6 total) Author Posts October 17, 2018 at 9:30 pm #94873 asp11Participant The element was wet to touch and the stat was open curcuit, so I assumed the heater was gone…. Fitted a new heater but still there’s No heat….. the 3 purple wires going to it from the pcb – I have power to the 2 end wires but still No heat?? Is this a pcb problem or is there something I’m missing? October 18, 2018 at 8:50 am #458614 electrofixModerator Are you sure its Samsung I get Siemens Dave October 21, 2018 at 8:42 pm #458615 asp11Participant Yes sorry it is a Siemens, my mistake But the problem is still the same, any ideas? October 21, 2018 at 9:46 pm #458616 electrofixModerator when you fitted a new heater, and tried the machine, did you have wet clothes in it as some dryers don’t turn on the heat unless they detect dampness Dave October 22, 2018 at 9:10 am #458617 asp11Participant Yes I did put a handful of damp clothes inside then let it run for a few minutes on 3 different settings but still no heat? I was convinced it should have worked?!! October 22, 2018 at 11:46 am #458618 electrofixModerator well my next step would be to check the solder joints on the relays. After that I would suspect relays and check if coil voltage was present or not Also did you try a timed dry as this can sometimes bypass some of the sensors Dave Author Posts Viewing 6 posts - 1 through 6 (of 6 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
