Samsung DV70F5E0HGW
  • #88998
    ChrisR
    Hiya.
    Not seen one of these before.
    No heat from drier.
    How easy is it to access the heater and where is the likely cause.
    Thanks.
    Lawrence
    Re: Samsung DV70F5E0HGW
    its a heat pump dryer so it doesn’t have a heater .
    If it has a fault then it should throw up a fault code ,if your customer is complaining of poor results make sure the condenser fins are clean.
    #439999
    ChrisR
    Thanks Lawrence.
    Fault code is HE
    #440000
    Lawrence
    There is a reset procedure ,but HE is normally the pcb or circ system or sometimes both.
    Either way mega bucks
    #440001
    ChrisR
    Thanks Lawrence.
    I think I’ll walk from this one.
