Samsung DV70F5E0HGW Tumble dryer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung DV70F5E0HGW Tumble dryer
  • #91537
    washingmachinewoman
    Hi all,
    Had the dubious pleasure of going out to one of these tumble dryers this morning. The noise it had developped was quite something! From what I had seen on the Ukwhitegoods forums, it looked like the problem was the blower fan. Made a beeline for it, and indeed it was in bits. However, it wasn’t the cause of the noise. The drum is juddering as soon as it gets to a certain speed.
    I think it’s the bearing at the back and possibly a distended belt (didn’t seem that tight to me). Could it also be the front rollers rather than or as well as the back bearing? They seemed in good nick.
    Cheers
    #448471
    washingmachinewoman
    Re: Samsung DV70F5E0HGW Tumble dryer
    In case anyone encounters same problem, fitted new back bearing and belt (also broken blower fan) today and it’s done the trick. Machine nice and quiet again.
    The hardest bit was remembering where the millions of screws went back as you pretty much have to strip down the whole machine.
    #448472
    Is that one of the horrid heat pump ones Lawrence still starts shaking quite violently when you ask him about them? 😉
    Lawrence
    Yep
    #448474
    washingmachinewoman
    Must admit I nearly didn’t want to know when I saw it had gas in it, but I kept well away from the sealed unit and the compressor and pipes, and all was well.
    Customer swears by it. Apparently, only costs £20 a year to run and dries very well. Except she just spent £120 having it fixed after less than 3 years… ‘cos the parts aren’t cheap!
    #448475
    garn
    hi happy 2018 .
    had a call this evening with a customer ERROR 5E on the screen UNABLE TO FIND WHAT THE CODE MEANS
    THANKS GARN PS SAME MODEL AS ABOVE
    #448476
    garn
    garn wrote:hi happy 2018 .
    does anyone know this fault code E5 please desperate
    #448477
    timdowning
    5E is normally a pump / drain issue on Samsungs
    #448478
    garn
    Thanks never seen 1 let alone work on one
    Ta Paul
    #448479
    BobHope
    Change the pump and the float sensor together, simple job they are both accessible from the back.
    bob.
