Samsung DV70FSE dryer HE
  • #88346
    snig
    Got a Samsung heat pump dryer stuck on HE fault code. Do you have to reset and if so how. Condenser was blocked but now cleaned. !!
    #437735
    twicknix
    Any answers? Got the same here…
    #437736
    its listed as compressor overheat
    have you checked compressor as there must be a temp measuring device be it stat or ntc
    twicknix
    Totally unrelated problem but this is the reset procedure and I found it works
    https://youtu.be/tSCaizu9BYk
    #437738
    looks like some sort of service access but good to know its there. need to experiment next time i see one
