Went to a Samsung heatpump dryer model DV80F5E5HGW/EU
Rear fan had shattered (still trying to source one, ordered one for the DV70 series, hope it fits!) and getting this error code (machine not starting)
dE
Can anyone help re error codes?
Cheers
Mike
Yes door was closed. Could be the interlock I guess. Will investigate when I fit the fan.
Thanks for info. By the way, is there a proper source of spares for these newish heatpump Samsung driers? I had a long search to source the fan, and then I had to go for the “70” series fan, as no-one had the “80” series fan.
Should also mention, for your DE error check the door as the pin can snap off if they have been slamming it shut. The pin is a moulded part of the door so can’t be replaced on it’s own.
