Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Samsung DV80H8100HW
- This topic has 11 replies, 2 voices, and was last updated 9 years, 5 months ago by
maunokoivisto.
October 19, 2016 at 12:10 pm #89636
maunokoivisto
ParticipantI have this heat pump dryer. The compressor cooling fan stopped and shut the machine down . Now it has a HE error code.
I repair appliances so the only question is how to reset?
( compressor tested, cooling fan replaced etc..)
Any ideas?November 9, 2016 at 5:35 pm #441945maunokoivisto
ParticipantRe: Samsung DV80H8100HW
No one know it in the whole forum?Hard to believe 🙂
November 9, 2016 at 7:29 pm #441946Lawrence
Try this ,but normally it needs a base assy as the compressor is knackered
November 9, 2016 at 7:53 pm #441947maunokoivisto
Thanks Lawrence i will do that. Te comp is not knackered as i have tested it.I fix fridges and replace compressors so i know too much about them 🙂 .
For example if i have to replace one i have the best tool to do it.
Rothenberger Rotherm 2000 .November 9, 2016 at 9:31 pm #441948Lawrence
That’s good news then as the compressor is not available as a spare part ,it comes as a completely sealed R134a system all pre installed on the base with the motor ,the most common fault was that when cleaning the condenser the cust managed to crush the fins ,the compressors also had a habit of becoming incredibly noisy but obviously you wont know that until it resets however the other thing to be aware of is that sometimes when they went HE you also had to change the PCBs as well. Obviously if you can clear the HE error given your knowledge you can ascertain wether the compressor is noisy or not.
November 9, 2016 at 10:07 pm #441949maunokoivisto
Even if the compressor would be dead, i could replace it it just a matter of hard soldering and getting the compressor from china (you can buy anything on alibaba):) Oh and also an F-gas certificate to buy R134a 🙂
November 9, 2016 at 10:53 pm #441950Lawrence
In which case knock yourself out fella
November 10, 2016 at 9:18 am #441951maunokoivisto
Sorry i don`t understand this last one 🙂
November 10, 2016 at 2:49 pm #441952maunokoivisto
I have tried to do whats in the description, but it wont go into test mode.I have tried few different ways but nothing.
November 10, 2016 at 4:22 pm #441953Lawrence
Then it requires PCB’s but like I says before beware the compressor as well
November 10, 2016 at 5:27 pm #441954maunokoivisto
Thanks for trying! 🙂
January 17, 2017 at 9:07 pm #441955maunokoivisto
Lawrence wrote:Then it requires PCB’s but like I says before beware the compressor as well
Thanks, replaced pcb and fan after as i said tested the compressor well with all my tools :).Works like a charm!
