Trying to fit door seal to this what a nightmare a had trying to get inner spring on. .. I couldn’t physically squeeze the wire together to get screw in ..brain damage I ended up cutting about ,2 cm of length of screw ..is their a trick to it ..and when I tried to tightened to. Much it got loser ..weird man 3 hrs took me just to get wire on
the wire band screw is anti clockwise thread tighten it fully so the 2 ends come together , slip it over the band then undo it fully and it will tighten the band, it defies logic but it works
Really it’s a left hand thread then that what you are Trying to.say ?it’still dosent help pushing wire enough to get screw in tho would it’s about a inch you have to move it impossible and I tried just levering it on no chance kept pulling seal off ? A think am losing the plot man
