Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Samsung ecobubble HE code error.
- This topic has 13 replies, 2 voices, and was last updated 5 years, 4 months ago by
Pabloz.
November 14, 2020 at 6:48 pm #98646
Pabloz
ParticipantHi all, I have a Samsung ecobubble model no. WF80F5E0W2W
It has stopped working with an HE error code which I am led to believe is a temp sender error problem. I have replaced this with a new one(access is very easy from the rear) but I still have the error code. I have unplugged it and left it to reset it but no joy. I cant see any problems with wires so far. Could it be a circuit board problem?
Any help most welcome!
November 15, 2020 at 2:37 pm #473174electrofix
Moderatorsee error descrition here
have you checked the heater ?
November 15, 2020 at 8:03 pm #473175Pabloz
ParticipantThanks for that Dave. I only pulled the heater and checked it visually. Whats the best way to test it?
November 15, 2020 at 8:10 pm #473176electrofix
Moderatorwith multimeter
you should get well under 100 ohms across the teminalsdave
November 16, 2020 at 7:57 pm #473177Pabloz
ParticipantHi Dave, checked with a multimeter and didnt get a reading so assume it must be this. Will order a new one- fingers crossed. Thanks for your help
November 22, 2020 at 11:23 am #473178Pabloz
ParticipantDarn it! Replaced element as well and still got the HE code. switched it on and off, unplugged it for a while and kicked it. Still no joy. Any other options??
November 22, 2020 at 11:31 am #473179electrofix
Moderatorwell if the heater is ok and conected correclty
the temp sensor is ok
the wiring back to the timer is okthen all that is left is the board as far as i know
November 22, 2020 at 2:04 pm #473180Pabloz
ParticipantProbably not worth it then. Its about 7 years old. I hate not being able to fix stuff though and end up throwing it away……
November 22, 2020 at 2:20 pm #473181electrofix
Moderatorproblem with both samsung and LG boards is they fill then with a jelly so it could be as simple as a dud relay but you can never fix them because you would have to cut the component out off this stuff first and you cant test components on the board for the same reason
November 22, 2020 at 3:46 pm #473182Pabloz
ParticipantThanks for all your help anyway, much appreciated! Need to look for a more reliable make of washer now……..
November 22, 2020 at 4:08 pm #473183electrofix
Moderatortop of the tree is miele
November 22, 2020 at 4:26 pm #473184Pabloz
Participantjust checked prices of Miele and my budget is about 400 quid so dont think i can put that on my list……….. you get what you pay for I suppose
November 22, 2020 at 4:55 pm #473185electrofix
Moderatorthe problem is in real terms due to market forces machines have got cheaper. that means the manufacturers have had to cut corners to bring down cost
what you have to do is work out what they are making them for
your budget is £400, Your buying from a retailer who has to make a profit, it has to be shipped half way round the world, the manufacturer has to also make a profit after paying for reseach and development. plus your £400 contains Tax at 20{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} so your £400 is really £330
in short your manufacturing cost of the machine could easily be less than £100 and you dont get much quality for that
dave
November 23, 2020 at 5:35 pm #473186Pabloz
Participanthmmm, doesnt add up to much quality wise, I agree. Think I should try and go for a compromise, somewhere in the middle of budget and Miele!
